HQ Drawing documents | Verify Accs KYC | Antiban 100% | PSD Templates
9 out of 10 edits fail KYC. And it’s not about a “pretty image”
▪ Mustang Service – when approval matters more than blind testing.
› We work with what systems actually check:
→ passing anti-fraud checkers: Onfido, Veriff, Sumsub, etc.
→ German-grade studio equipment
→ two-stage control + metadata cleaning before submission
→ ELA analysis bypass
→ data structure and logical consistency
▪ While this post is still live – a private bonus is available.
› Message us – we’ll break down your case.
› TG: @mustang_service_ms ( https:// t.me/ mustang_service_ms )
› Channel: Mustang Service ( https:// t.me/ +JPpJCETg-xM1NjNl )
#documents #kyc #photoshop #editing #graphics
HOW TO PHOTOGRAPH A SEAL SO IT DOESN’T BECOME A PROBLEM
When a document has a seal, the quality of its rendering depends directly on how well you photographed it. A poor photo of the impression almost always turns into a headache during the final stages.
▪ What matters when shooting:
- use side (oblique) lighting to reveal the relief of the seal
- take several shots from different angles — straight on and with a slight tilt
- keep the background neutral so it doesn’t blend with the color of the seal
- avoid using flash — it flattens texture and volume
- shoot in macro or get as close as possible while maintaining sharp focus
🧠 A seal isn’t just a decorative element. It’s an important part of the document that often undergoes separate verification.
Want the seal on your document to come out as clear and accurate as possible?
Send us a photo of the seal in DMs — we’ll advise you on how to reshoot it properly or handle the redraw ourselves.
#documents #drawing #photoshop #editing #seal
WHEN IT’S BETTER TO SAY “NO”
Not every project is worth taking on. Sometimes turning down a request isn’t losing a client — it’s protecting both them and ourselves.
Over the years, we’ve learned to quickly recognize when a project is almost certain to run into serious problems. Here are the most common stop-cases we encounter:
▪ The client wants it “like everyone else’s,” but with custom changes and at the lowest price
▪ There are no proper source materials, yet the deadlines are already burning
▪ Constant changes to requirements and conditions after the work has already begun
▪ A task with a very low chance of success, but very high expectations
▪ The client isn’t ready to discuss the process and sees us as just an executor
🧠 A good result almost always starts with both sides having a clear and honest understanding of the risks and possibilities.
If you’re currently discussing a project and unsure whether to move forward — write to us. We’ll honestly tell you whether it’s worth taking on or if it’s better to look for another solution.
#documents #drawing #stop_case #editing #reject
A BAD CLIENT PHOTO ISN’T A DEATH SENTENCE
People often send photos that make you want to reject them right away — blurry, poorly lit, taken in a hallway on the go. But it’s not always necessary to ask for new ones. Sometimes you can still pull a workable version out of such material.
▪ What can realistically be saved:
- weak or uneven lighting (through color correction and local adjustments)
- minor skin imperfections and small artifacts
- average sharpness (with proper sharpening and texture work)
- imperfect angles (through light perspective and proportion correction)
▪ What almost always kills the case:
- heavy blur and “soapiness”
- very low resolution
- strong facial distortion from wide-angle shots
- completely destroyed lighting (deep black holes or blown-out areas)
🧠 The main rule: don’t try to turn a bad photo into a perfect one. The goal is to make it good enough to pass verification.
Send us your “problematic” photos in DMs. We’ll honestly tell you whether it’s worth working with them or if it’s better to look for other source material right away.
#documents #drawing #low_quality #editing #bad_photo
KIDS HAVE ALREADY HACKED AGE VERIFICATION
▪ A recent UK survey found that schoolchildren are easily bypassing “18+” checks on adult websites. Some simply draw on a mustache with an eyebrow pencil, and the system registers them as adults. Others point the camera at in-game characters who look older.
This isn’t a joke. It shows just how easily current automated age verification systems can be fooled.
▪ What this reveals about today’s methods:
- simple physical tricks still work
- neural networks often rely on superficial features
- many platforms still use fairly weak verification processes
🧠 While age verification remains vulnerable, high-quality documents with proper biometrics and serious verification continue to be one of the most reliable ways to confirm identity.
If you need to pass real, serious verification — not the kind that kids can bypass with a pencil — write to us in DMs. We’ll review your case and make sure it actually works.
#verification #drawing #photoshop #editing #smart_kids
WHEN SAYING “YES” IS A MISTAKE
Not every project is worth taking on, even if the client is ready to pay. Sometimes refusing isn’t about losing money — it’s about protecting your reputation and time.
Over the years, we’ve learned to quickly spot the cases that are almost guaranteed to turn into problems. Here are the most common situations where we turn down work:
▪ The client wants it “like everyone else’s,” but with lots of custom changes and on a minimal budget
▪ There are no proper source materials, yet the deadlines are already burning and everything is needed “yesterday”
▪ Constant changes to requirements after the work has already started
▪ The client isn’t willing to discuss the process and sees us as just an executor
🧠 A good result almost always starts when both sides have an honest understanding of the risks and real possibilities of the project.
If you’re currently discussing a project and unsure whether to move forward — write to us. We’ll honestly and directly tell you whether it’s worth taking on or if it’s better to look for another solution.
#documents #drawing #photoshop #refuse #cases
PLATFORMS LINK YOUR CASES
Many clients assume that every new case is a completely separate story. In reality, modern platforms have long learned to detect connections between different applications, even when they are submitted at different times and with different data.
▪ What they actually “see”:
- similar elements in photos (even after editing)
- matches in metadata and device information
- similar behavioral patterns and phrasing
- overlapping timing and geographic data
- hidden links through previous rejections or connected profiles
🧠 Sometimes two “independent” cases start dragging each other down precisely because of these non-obvious overlaps.
✏️ If you already have multiple cases or are planning to submit a new one, it’s better to understand in advance which connections might surface.
Write to us in DMs. We’ll review your situation and show you what to pay attention to so that different cases don’t start working against each other.
#drawing #verification #platforms #editing #link
FAKE FLIGHT ATTENDANT WITH 30 CREW IDs
In the US, a man successfully posed as an employee of seven different airlines for six years. He used around 30 fake crew IDs that gave him access to business lounges and staff travel benefits, including free or discounted flights.
He moved freely through restricted airport areas, enjoyed crew privileges, and raised almost no suspicion — until the system finally caught up with him.
▪ What allowed him to stay under the radar for so long:
- high-quality fake IDs
- good knowledge of internal procedures and real crew behavior
- lack of strict cross-airline verification
If you work with documents, access control, or verification — it’s important to understand where the real line between “looks real” and “actually works” lies today.
Write to us in DMs. We’ll review your case and help make sure your documents don’t become part of someone else’s “successful” story.
#drawing #ID #photoshop #editing #news
