HQ Drawing documents | Verify Accs KYC | Antiban 100% | PSD Templates
9 out of 10 edits fail KYC. And it’s not about a “pretty image”
▪ Mustang Service – when approval matters more than blind testing.
› We work with what systems actually check:
→ passing anti-fraud checkers: Onfido, Veriff, Sumsub, etc.
→ German-grade studio equipment
→ two-stage control + metadata cleaning before submission
→ ELA analysis bypass
→ data structure and logical consistency
▪ While this post is still live – a private bonus is available.
› Message us – we’ll break down your case.
› TG: @mustang_service ( https:// t.me/ mustang_service )
› Канал: Mustang Service ( https:// t.me/ +JPpJCETg-xM1NjNl )
#documents #kyc #photoshop #editing #graphics
“CAN’T YOU JUST MAKE IT RANDOM?” – HERE’S WHERE IT BREAKS
▪ Case: request for a USA passport “based on data”.
No photo, with random generation.
▪ At first glance – simple.
In reality – a minefield.
▪ What was provided:
– full name + address
– SSN
– DOB
– request for “any photo”
▪ Where it breaks:
data isn’t connected
address ≠ document region
age, photo, and format don’t match
SSN follows its own logic
▪ And the key point:
“random” ≠ “realistic”
▪ Most of these files fail not visually,
but due to internal inconsistencies.
▪ What was done:
linked all data into a coherent logic
aligned region, age, and structure
built the scene so it “behaves” correctly within the format
▪ A document is not just an image.
It’s a system where everything must match.
▪ Got a similar case?
Describe it – we’ll show where it breaks before submission.
› Channel: Mustang Service ( https:// t.me/ +JPpJCETg-xM1NjNl )
#editing #photoshop #documents #case #antifraud
A NEW DOC… THAT LOOKS OFF
▪ Another paradox: the “fresher” the document looks – the more questions it raises.
📄 In reality, even a new object is never perfect.
→ micro-scratches appear from the very first contact
→ edges start to wear out almost immediately
→ usage patterns form faster than people think
📌 Now what gives it away:
perfectly clean surface
overly sharp, “plastic” edges
no signs of interaction at all
❗ Such a file doesn’t look new.
It looks unnatural.
📉 The eye accepts.
The system analyzes behavior.
💡 Wear is not a flaw.
It’s proof of reality.
✉️ Want to see where your “new” doc already raises flags?
Send it – we’ll show where it looks too sterile and fix it.
#redraw #photoshop #documents #wear #antifraud
AI GOT IT WRONG — A PERSON WENT TO JAIL
▪ 2025. A woman from Tennessee spent ~5 months in jail…
because an algorithm “recognized” her in the wrong place and case.
🧠 What happened:
– a fake ID photo
– processed through a face recognition system
– “match” → warrant → arrest
📌 No proper verification. No logic.
Just because “the system said so”.
❗ As a result:
a person who had never even been to that state
ended up behind bars.
📉 The alibi was proven only later —
with banking records.
💡 And here’s the key point:
the algorithm searches for similarity,
not truth.
▪ New users — 15% discount until the end of today.
✉️ If you think “it’ll pass anyway” —
in 2026 it doesn’t work like that anymore.
Send us your case – checkers will “recognize” your doc and a successful verification won’t take long.
#redraw #documents #verification #news #antifraud
A FRESH DOC… BUT IT LOOKS LIKE A MOCKUP
▪ The most common mistake – a document that looks “too new”.
That’s not how real life works.
▪ Reality starts with contact.
– micro-scratches appear from the very first touch
– edges slightly “settle” with use
– friction leaves its own unique pattern
▪ What most people do instead:
leave the surface perfectly clean
draw ideal, “plastic” edges
forget that a document lives, not sits in a vacuum
▪ The result is not “new” –
it’s suspiciously artificial.
▪ The eye doesn’t argue.
But the system looks at behavior.
▪ A real document always has a story.
Even if it was “issued yesterday”.
▪ Want to check if your file looks alive or like a template?
Send it – we’ll break down the wear and show where it gives itself away.
#redraw #photoshop #documents #wear #verification
EVERYTHING LIT THE SAME? YOU’RE ALREADY CLOSE TO FAILURE
▪ The quietest mistake – “perfect lighting”.
Clean, even, with no variation… and completely exposed.
▪ In reality, light is never uniform.
– there are always gradients and falloff
– different areas catch light differently
– objects don’t glow as one flat layer
▪ What most people do:
flood the scene with uniform light
remove shadows and transitions
make it “studio-like” – sterile and smooth
▪ The result is not a photo,
but a flat image with no depth.
▪ The eye might accept it.
But checkers look for light variability.
▪ Real light always “breaks”:
brighter here, fading there, lost somewhere else.
▪ Don’t want to worry about lighting in your file?
Message us – we’ll adapt the lighting for any task.
#redraw #photoshop #documents #light #lighting
18,700 FAKE DOCS – AND THAT’S JUST ONE SCHEME
▪ In Romania, a network was exposed:
thousands of people received fake documents.
▪ According to reports:
– 18,700+ recipients
– Russia, Moldova, Ukraine
– including criminal suspects and sanctioned individuals
▪ But the numbers aren’t the main point.
What matters is how it worked:
volume
mass processing
template-based solutions
▪ And that’s exactly why these stories always end the same way – raids and shutdowns.
▪ Because systems have long learned how to detect “mass patterns”.
▪ Today it’s not individuals who get caught.
It’s those who operate at scale.
▪ Want your case to not look like part of a “conveyor batch”?
Describe your task – we’ll show where it can get flagged even before verification.
#redraw #documents #verification #news #romania
“JUST FIX THE DATE” – SURE, BUT IT’S NOT THAT SIMPLE
▪ At first glance, the case looked simple:
a selfie with a document + a sheet with a date and number.
▪ The task – update the date and remove extra digits.
The client had already tried to do it themselves… and that’s where everything fell apart.
▪ Where it broke:
– the date was “copied” in shape – it looked unnatural
– lines and tilt didn’t match the paper
– digits stood out by thickness and pressure
– editing traces were readable at the structural level
▪ These things don’t fail instantly,
but under careful comparison with the original.
▪ Even if it “looks fine” to the eye –
the system sees behavior inconsistencies.
▪ What we did:
– rebuilt the digit shapes to match natural handwriting
– adjusted tilt, pressure, and placement to the sheet
– synchronized the scene with the main photo
– carefully balanced the structure without visible editing traces
▪ As a result, the image came together into one logic,
instead of looking like an overlay.
▪ In tasks like this, it’s not about the tool,
but about understanding how a real object behaves.
▪ Referral bonus:
– 15% off for the person who recommends us
– and 15% off for the person who comes by referral
(valid on the day of this post and the following day)
Describe the task – we’ll show where it breaks and how to assemble it properly.
*All data in this case is presented with the client’s consent*
#redraw #photoshop #documents #case #verification
