HQ Drawing documents | Verify Accs KYC | Antiban 100% | PSD Templates
PASSED KYC — AND A MONTH LATER ANOTHER CHECK
Previously it was enough to submit documents once and forget. Now platforms more often launch repeated audits, especially with suspicious activity or antifraud updates.
The system starts looking not only at the current file, but at the history: whether the grain matches, whether patterns repeat, whether old metadata surfaces. What passed in January can already raise questions in August.
That is why a one-time “pretty” document often does not survive a delayed check. You need a file with a safety margin and a clean digital biography.
If after a successful KYC a repeated check arrived or the account started failing — write. We’ll break down the old file and build a new one under the current requirements.
› TG: @mustang_service_ms ( https:// t.me/ mustang_service_ms )
› Channel: Mustang Service ( https:// t.me/ +JPpJCETg-xM1NjNl )
#drawing #kyc #verification #replay #recheck
9 out of 10 edits fail KYC. And it’s not about a “pretty image”
▪ Mustang Service – when approval matters more than blind testing.
› We work with what systems actually check:
→ passing anti-fraud checkers: Onfido, Veriff, Sumsub, etc.
→ German-grade studio equipment
→ two-stage control + metadata cleaning before submission
→ ELA analysis bypass
→ data structure and logical consistency
▪ While this post is still live – a private bonus is available.
› Message us – we’ll break down your case.
#documents #kyc #photoshop #editing #graphics
ACCOUNT FROZEN. WHAT NOT TO DO
Most people’s first reaction is to start spamming support, uploading everything at once, and opening multiple tickets. This often makes the situation worse.
▪ What to avoid:
- multiple requests with different explanations
- uploading old files without review
- panic-changing data
- logging in from new devices right after the freeze
Every extra action leaves a trace. During review this can work against you.
First, calmly gather the picture: what the notice says, which data was used before, and what has changed.
If your account was just frozen and you want to act without unnecessary mistakes — write to us. We’ll outline the proper sequence of steps and help with that.
#drawing #kyc #photoshop #frozen #account
FORENSICS SEES WHAT A NORMAL PREVIEW DOESN’T
A file can look perfect. No artifacts, good quality, everything in place. But during deep inspection, old traces surface: previous saves, software fingerprints, leftover metadata, edit history.
These are the things that increasingly cause questions during verification and re-audits.
▪ What is usually found:
- traces of previous editors and versions
- mismatches in creation and modification times
- remnants of old profiles and devices
- repeating technical patterns
Ordinary “metadata cleaning” often doesn’t remove everything. Forensics digs deeper.
If you need to understand what might surface in your file during a serious check — write to us. We’ll break it down.
#drawing #verification #photoshop #editing #forensics
GRANDMA FLED THE TRAIN
In Mogilev (Belarus), an elderly woman solved the issue of discounted train travel in a simple way: she took her father’s disability certificate, glued her own photo into it, and used it.
Until one day she got caught. A conductor on a diesel train took a closer look. The inconsistencies were too obvious. The woman didn’t try to explain herself — she simply got off at the nearest stop and put some serious acceleration into her lower limbs.
The story sounds almost like a joke. But it contains a very precise point: even the most “homemade” forgery falls apart the moment someone starts looking at it properly, not just formally.
You can glue a photo in. Making a document that actually withstands real scrutiny is a completely different job.
If you need something that isn’t done “on the fly,” but a document that calmly passes verification — write to us. We’ll look at the task and tell you how best to handle it.
#drawing #certificate #photoshop #editing #news
MICRO-ARTIFACTS THAT EXPOSE A DEEPFAKE
Systems no longer mainly look at “similar / not similar”. They search for small violations: edge trembling, unnatural shine, errors in teeth and hair, light and shadow desync.
These are the things that most often cause rejection, even when at first glance everything looks decent.
▪ Typical traces:
- floating face edges
- problems with teeth and mouth cavity during speech
- unnatural highlights on eyes and skin
- slight desync between head movement and facial expressions
The higher the deepfake quality, the more carefully these areas need to be handled. And the more closely they are checked.
If you need a high-quality, convincing deepfake to pass a live verification check? Write to us.
#drawing #verification #artifacts #editing #deepfake
REPEAT CLIENT: UKRAINIAN FOREIGN PASSPORT FOR THE REQUIRED NAME
The client came back again. This time he needed a rendering of a Ukrainian foreign passport with a specific first and last name. The task was simple in wording: make a document for Google, the main thing was that the required data was in place.
There was no proper face photo. The client immediately said that he had registered the account simply with a first and last name, so only the matching of the data was critical. He had ordered similar work from us before, and it had gone through successfully.
Here’s what we did:
- prepared the passport spread with the specified data
- selected a suitable photo for the document format
- maintained the structure and design of a Ukrainian foreign passport
- delivered the finished file without unnecessary revisions
The client received the result and confirmed that everything was excellent.
Sometimes the task sounds extremely simple: you don’t need a “perfectly lifelike document,” but an exact match of the first and last name for a specific check. In such cases, speed and accuracy of execution matter most.
Need a rendering with specific data?
Write to us. We’ll review the task and handle it carefully.
#drawing #kyc #photoshop #foreign #case
THEY DIDN’T FAKE A DOCUMENT — THEY FAKED AN ENTIRE IDENTITY
In August, Huntress described cases where IT specialists applied to foreign companies under stolen or synthetic identities. The materials included a residence card, a Chinese passport, an electricity bill as proof of address, and a photo taken from someone else’s GitHub account and altered to look like another person.
In one case, the person had already been hired by a financial company. After a security agent was installed, unusual remote-access devices showed up. The scheme wasn’t built on a single file, but on the whole chain: face, documents, address, hardware, and work profile.
▪ What matters here:
- they no longer check “one form,” but the entire biography
- one weak link is enough for the whole construction to collapse
- photo, address, and document have to add up, otherwise it shows during a deep review
One good-looking file no longer saves the case. They look at how all of it lives together.
Need materials that hold up not only at first glance, but also under a linked review?
Write to us. We’ll look at the task and tell you what can actually be done.
#drawing #identity #photoshop #editing #news
REQUIREMENTS CHANGE EVERY 2–3 MONTHS. OLD FILES BURN
What passed in January already gets rejected in April. Antifraud updates quietly and constantly.
Allowed compression levels change, grain requirements, metadata check logic, acceptable sharpness deviations and even how the system looks at the edges of inserted elements. Yesterday a certain noise level still worked – today it’s on the blacklist.
That’s why keeping “eternal” templates is pointless. A pro rebuilds the document every time under the current logic of the specific platform.
If your old file suddenly stopped passing – drop it. We’ll tell you exactly what changed in the checks and how to bypass it right now.
#drawing #antifraud #photoshop #editing #updates
